Overcurrent Protection No hardware shutdown. Software interrupts do not have the highest priority, why?
The optimal solution should be a hardware shutdown.
Interrupt priorities are assignable, pick any order you want.
The LPComp output can be routed directly to the STOP input, this functions the same as a KILL.
There is some variation between parts. Which one are you using? I can investigate a little further.
---- Dennis Seguine, PSoC Applications Engineer
