I'm now using a MiniProg3/kitprog3 to debug the board. Due to certain restrictions, I am wondering if i can debug it without the Reset cable, only using 5V, GND, SWDIO and SWCLK. Or is the Reset cable essential for debugging ?
If it is realizable, how should i set the configuration ?
PSoC 4 MCU
I understand that you are using a system power supply, not MiniProg.
When powering from MiniProg with USB bus power(200mA or less), you can debug without a reset signal, however in the case of system power supply, I think that it can not be supported even in power cycle mode.
In that case, I can only think of way to connecting the PSoC4 XRES and the MiniProg XRES.
I'm sorry for not being able to help.
