songzaiwu
50 sign-ins 10 questions asked 25 sign-ins
About Single Resistor Sampling FOC. Is there any documentation? Can the program code be made public?
Raj_C
500 replies posted 50 likes received 250 replies posted
Hi @songzaiwu,
Please refer to section 5.6 of the CY8CKIT-037 PSoC 4 Motor Control Evaluation Kit User Guide. It explains the Single Shunt FOC implementation.
The code example is available under the software tab of the CY8CKIT-037 web page.
Please, let us know if you have further questions.
Thank you
Best Regards
Raj Chaudhari
Raj_C
Hi @songzaiwu,
Thank you
Best Regards
Raj Chaudhari
What if the sampling time is very close?
Raj_C
Hi @songzaiwu,
As per the CY8CKIT-037 PSoC 4 Motor Control Evaluation Kit User Guide.
The reason to trigger the ADC sampling in the middle of the pulse is to avoid the transient noise caused when the PWM signal changes state. In the middle of the pulse, it will be more stable.
So, it is not recommended to trigger pulse for the sampling other than mentioned in the document.
Thank you
Best Regards
Raj Chaudhari
songzaiwu
If T1/2 or T2/2 is less than the minimum sampling time, then the sampling is not correct, how does the program handle it?
Raj_C
Hi @songzaiwu,
The value of T1/2 and T2/2 are computed every cycle based on previous data values. Hence the particular scenario under consideration may not occur. We would like to know if any specific case is observed during the development stage at your end.
Thank you
Best Regards
Raj Chaudhari
