I have a question about CapSense_SetParam API for PSoC4000S.
If I set "CapSense_BUTTON0_IDAC_MOD0_PARAM_ID" for argument "uint32 paramId", the BAD_PARAM is returned.
Maybe "CapSense_BUTTON0_IDAC_MOD0_PARAM_ID" is not writable.
Is this correct?
What spec says that "CapSense_BUTTON0_IDAC_MOD0_PARAM_ID" is not writable?
Yocchi
PSoC 4 MCU
Hello Yocchi-san,
The CapSense paramIDs follow a specific byte format -
The 3rd bit from the MSB (or the bit in position 29) indicates if the particular param is Read/Write capable.
For example, consider the paramID for CapSense_BUTTON0_IDAC_MOD0_PARAM_ID which is 0x4E000027 in my case. The MSB byte is 4, which indicates the bit in position 29 is 0. This indicates that the parameter is read-only.
If we consider the finger threshold parameter, CapSense_BUTTON0_FINGER_TH_PARAM_ID, the paramID is 0xAB800020. Here, the MSB byte is 0xA which indicates the bit in position 29 is 1 and hence, this parameter is Read/Write.
Please let me know if you have any further queries.
Hari
Hello Yocchi-san,
Hari
Hello Hari-san,
I looked at my "CapSenseRegisterMap.h" and "CapSense_BUTTON0_IDAC_MOD0_PARAM_ID" is below.
#define CapSense_BUTTON0_IDAC_MOD0_PARAM_ID (0x4C00002Fu)
So, 'W' is '0'.
Thank you very much.
Yocchi
