Tim_Shih
250 sign-ins 50 replies posted 50 questions asked
Hi ~ all,
I use Cap sense sample code but there are 2 error messages in the following description.
Could anyone know what happened ?!
main.c:121:55: error: 'CapSense_BUTTON0_WDGT_ID' undeclared (first use in this function)
CapSense_BUTTON0_WDGT_ID,
main.c:121:55: note: each undeclared identifier is reported only once for each function it appears in
main.c:122:55: error: 'CapSense_BUTTON0_SNS0_ID' undeclared (first use in this function)
The command 'arm-none-eabi-gcc.exe' failed with exit code '1'.
Thank you so much.
Tim_Shih
I just tried again and I found there were no button in the cap sense block. After I add a new one, no error messages now. Thank you for your help.
Roy_Liu
First comment on KBA 10 questions asked First comment on blog
Hi Tim,
This is mostly because of the Capsense Component name on your TopDesign is named as other than "Capsense"
or the Button name is not "Button0" in the Capsense component configurator:
Roy Liu
Tim_Shih
