About CYAT817AZS61-3A002 drive debugging
Translation_Bot
Community Manager
Community Manager
Community Manager
Hello!
Some projects need to use an MCU to read the TOUCH coordinates and point status (press, lift, move) information, and then send it to the main control MCU;
Is there any CYAT817AZS61-3A002 documentation on the TOUCH register, similar to the one in the attached picture.
Use official debugging tools, then use a logic analyzer to capture IIC bus data. I don't know the specific meaning of the data;
数据数据data
You need to know the specific meaning before you can debug the MCU driver. If you can't find any relevant documentation, ask for help.
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/PSoC-4/%E5%85%B3%E4%BA%8ECYAT817AZS61-3A002%E9%A9%B1%E5%8A%A8%E8%B0%83%E8%AF%95/td-p/670587
Translation_Bot
Community Manager
Community Manager
Community Manager
We have a register map document, but this document is a control document and requires the customer to sign an NDA before it can be obtained. For specific steps, please refer to the steps for registering myICP mentioned in the CYAT817X data sheet to apply for permission. Once you have obtained permission by following the process, you can directly access the ICP server to download this data directly.
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/PSoC-4/%E5%85%B3%E4%BA%8ECYAT817AZS61-3A002%E9%A9%B1%E5%8A%A8%E8%B0%83%E8%AF%95/m-p/670833
