I am developing application on PROC4 BLE as a central device. My side is client side.After passing address of peer device to which my device wants to connect to the Gapc_connectdevice function it gives api result :CYBLE_ERROR_INVALID_STATE which is explained as : On calling this API not in Disconnected state.
I have called Cyble_gapcstopscan() and CyBle_GapDisconnect(cyBle_connHandle.bdHandle) before calling Gapc_connectdevice () function.
But it still shows "not in Disconnected state" result and hence CYBLE_EVT_GAP_DEVICE_CONNECTED is also not generating.What is exact meaning of this api result?
What are the possible faults?
BLE
When you call StopScan API, the CYBLE_EVT_GAPC_SCAN_START_STOP API should be triggered, Only after this event is triggered, you need to call the ConnectDevice API.
Also, you can use the CyBle_GetState API to see the state of the device then and there,
-Madhu Sudhan
What does the state CYBLE_STATE_STOPPED mean? Is it indicating the scanning has stopped?
Thanks a lot !!..
