Hallo, about CY8C4014PVI-42, has it ADC? I tried on Psoc creator, and a message say to me, I need to use the capsens, is it?thanks John
Hi @hesc_1314511,
The CY8C4014PVI-42 has limited ADC function provided by capacitance sensing block. The CapSense block can also be re-purposed to implement a limited ADC function, which is only available when not using the block for capacitive sensing.
You can refer to the Code Example ‘CSD ADC with multiple inputs example project’ in PSoC creator to implement the ADC using CSD_ADC.
Please let us know if further clarification is required.
Thank you
Best Regards
Raj Chaudhari
