D_Sd_3235936
Level 4
Level 4
25 sign-ins 50 questions asked 25 replies posted
HI
Encountered this rare behavior in some of my devices running PSoC BLE 4200.
After sending the ACD module to sleep using  XXX_Sleep()
On wakeup, using XXX_Wakeup, a conversion started, and conversion timeout occurred. (This later was followed by a watchdog reset...)
My question is why did this conversion take place? I did not ask for it.
My ADC is configured to HW trigger mode.
Vasanth
Could you give more information ? Will you able to share your project ? What is the input to the hardware trigger pin of the component ?
Vasanth
Vasanth
Hi ,
I understand the ADC SOC pin is left floating. So I expect you to initiate conversion using ADC_StartConvert() API each time, when you want to initiate a conversion. But the information is not sufficient to test or recreate the issue at our end. Is it possible to share your complete project?
Vasanth
