Equip yourself to optimize PSoc4 MCUs for Evs at the EV Webinar. Click here to register.
PSoC™ 4 Forum Discussions
shge_4395051
Level 4
Level 4
25 replies posted First solution authored 10 replies posted
I'm using PSOC creator 4.2 and a prototyping kit "CY8CKIT-147".  I have two questions.
First, when I drop in a SAR ADC, it has a "prototype" watermark appended to it.  Why is this?
Second, I cannot seem to add an analog 4x1 MUX to my design.  I could really use two of these but adding only one triggers a macrocell resource error.
Here are the current resources in my design:
1 Soft Uart
1 SAR ADC
1 OpAmp
Do I need a larger device to accomplish this project?
Shawn
shge_4395051
Level 4
Level 4
I solved the issues with adding the muxes.  I had previously copied muxes from one schematic that used a different device to my current schematic.  I now know not to do this again.
The ADC still displays as a prototype device though.
Vasanth
Hello Shawn,
What is the component version you are using ? Could you go to tools and press Find new component option and confirm components are up-to-date ?
Vasanth
I updated the Scanning ADC but it still has a “Prototype” watermark on it. The datasheet shows it with the “prototype” watermark too. I must have the most up to date version. I’d like to know what this watermark means.
Shawn Gerber
Manufacturing Engineer Manager
Wagner Electronic Products Inc.
326 Pine Grove Road
Rogue River, OR 97537
Office: (541) 582-0541 x238
http://www.WagnerMeters.com/<http://www.wagnermeters.com/>
Vasanth
Hello Shawn,
Could you please share your project ? In PSoC Creator ,  go to File -> Create Workspace Bundle -> Select minimal. Please attach the generated file.
Vasanth
