Hello all,
I am using a PSoC 4 BLE Kit
CY8CKIT-042-BLE
I am doing a simple lab to teach my class about ADCs and Photo resistors and how to view the ADC result in putty.
mVolts=ADC_CountsTo_mVolts(0,ADC_GetResult16(0));
sprintf( output, "I am reading = %d mV \n", mVolts );
UART_UartPutString(output);
CyDelay(100);
I have everything working, however I noticed that my output was capped at 1024mV, I learned this was because on my ADC Block i had the VREF set at the 1.024 Volts ByPassed. I changed this to VDDA, which was set in the system at 3.3 but I was supplying it with 5. So when I programmed it, it capped out again at ~3000mV. So I went into the system and changed VDDD,VDDA,VDDR to 5V, now when I programmed it my values are off. When my multimeter reads about 700mV the PSOC reads about 1200mV, also when I shine a light on my photoresistor PSOC says it reads 5000mV when my multimeter reads about 4000mV. Is there some setting in the ADC SAR SEQ block I need to fix to get the accuracy back? or should I just power it with 3.3v which was just as accurate as the multimeter.
Thank you for your time in helping me
Hi Charles,
Could you please check your VDDA value using the multimeter and give that value in CYDWR -> Systems tab . Normally it will not be exactly 5V. Please let me know the results after the change.
VRS
Hi Charles,
VRS
Thank you that worked, I was using the 5V out on the programming board so I thought that would be the same as the VDDA, but measured the VDDA and it turned out to be 4.6V for this one. Again thank you it works as I want it to now.
