Hi, I need to know which solutions you ( CYPRESS and INFINEON) have in terms of Microcontrollers + Firmware fro those microcontrollers, to control a 3Phase ACIM motor with one sensor. . OUR POwer stage is IM564 from IFX with common output emitters, therefore we need single current sensor solution ( I mean the Firmaware).
Application is a 1,5KW whater pump. We need the application for one sensor.
PLease let us know the Cypress ( PSOC) and the IFX ( XMC )solutions as well.
thanks in advance
BR
MAnuel
PSoC 4 MCU
- RTK
Hi @maes_4835196 ,
XMC 1300 and XMC 4400 series support ACIM and please find the example application of the same in below link
iMotion ( IMC100 series) controllers also provide Induction motor control application please find application note in below link
Single shunt current measurement is supported.
Krupashankar
Hi @maes_4835196 ,
Krupashankar
