Aug 05, 2016
07:26 PM
Aug 05, 2016
07:26 PM
I'm doing a silly project where i have an array of random numbers and i would like to transfer each element of the array to the GPIO Port 1 with DMA, each transfer must be done when the user on-board button is pressed.
The DMA component is configured to transfer Byte -> Word, incrementing the source one element after each transfer.
I thought the following line will make the project run, but it seems like it does not:
DMA_Start((void *)array, (void *)Pins_DR);
Any thoughts?
I'm mostly new to PSoC 4 DMA so maybe there's a obvious mistake. I'm using the CY8CKIT-043 board.
Project is attached. thanks in advance
Carlos
