Can you confirm whether the CY8C4127AXI-S443 has CSD capsense support or not.
According to the datasheet it does not, but I am able to load the component into the project designer, assign pins and build without errors. It even shows 1/1 CapSense used in the resource monitor. Typically when a component/peripheral is not available it will cause build errors.
Hi @Alex_K,
Are you referring to the CapSense component which is already present in the schematic?
Yes, you are right.
Do not use CapSense component for the MPN not having CapSense support. Refer to this thread regarding the same issue:
https://community.infineon.com/t5/PSoC-4/Build-result-of-CY8C4146AZA-S245-without-CSD/m-p/278124
Thanks and regards,
Nikhil
