DaEr_349131
25 likes received 50 sign-ins 5 comments on KBA
  • Is it possible to run power mode 1 (powering the psoc with a 4-5V supply), and get the IO voltages to be 1.8V
  • How much current can VCCD provide (assuming we use this 1.8V tap to power some low-current peripheral IC's)
From the datasheet below:
Mode 1: 1.8 V to 5.5 V External Supply
In this mode, the PSoC 4000S is powered by an external power supply that can be anywhere in the range of 1.8 to 5.5 V.
The IO voltage is derived from VDDD.
Achim
AchimE_41
10 sign-ins 5 sign-ins First comment on KBA
No, this is not supported.
Achim
how about the io voltage, will that be 1.8V or 1:1 with the supplied rail, ie 3.6-4.2v running off a lipo battery!?
Achim
