SeYu_4806351
I'm making wireless switch USB with CYRF8935 module and MCU (ATmega48).
And I have some troubles with C coding.
I had read the datasheet several times, and set the registers according to the guide.
1)
Should I program the register in specific order?
I had just programmed register from 1 to 50 in order. I guess it's the biggest problem (maybe).
2)
CYRF8935 is programmed byte by byte, but some register(Reg52) has both read only and writable bit in one byte.
How should I program registers like this case?
3)
The packet structure is preamble + sync word + trailer + FIFO data. FIFO data are wrote in register 50, but I can't find the registers to program preamble and trailer.
Which registers are used to program preamble and trailer?
I'm beginner in transceiver and MCU, so I have too many troubles with programming. I attach the C code of Tx.
Thank you for reading. I really appreciate any help.
DheerajPK_41
This part is obsolete and it has limited support. All our new wireless designs are for Bluetooth / WiFi.
(https://www.cypress.com/products/wireless-connectivity)
Please refer below links to get the design documents and example projects for wirelessUSB.
https://www.cypress.com/products/wirelessusb-nl
https://www.cypress.com/documentation/datasheets/cyrf8935-wirelessusbtm-nl-24-ghz-low-power-radio
Please let us know if you have any specific concern to share.
-Dheeraj
DheerajPK_41
-Dheeraj
