Tle 6228 gp
User19081
En(Enable) Pin is high
STBY(Standby) Pin is high
Input Pin is low
Output is short circuit to ground
If the IC is set to the above conditions the output mosfet should be off but it is being observed that the mosfet is actually in on state so please explain the logic behind it and revert back asap.
