Dec 08, 2022
06:25 AM
Dec 08, 2022
06:25 AM
Hey, We are building modular car with steer by wire technology in it. Upon calculations, we figure out the Torque and Power values for motors in Steering wheel and Steering Actuator, that is 11Nm and 240W respectively for Steering Actuator and 6Nm and 102W respectively for Steering Wheel. With turn radius 7 m and Wheel base being 2150 mm and Track width being 1280 mm, the inner and outer steering angle being 16.69 and 18.28 degrees respectively. It is also low top speed around 60-80 kmph. So, I need consultancy from Infineon on specifications provided and help us with acuring outsourced components. Thank you in advance.
