May 25, 2021
01:21 AM
May 25, 2021
01:21 AM
Hi All,
I have gone through all earlier posts.
I have below queries if answered will be great help and appreciated.
Do we need to pull-up MTP pin to 3.3V to program(MTP).If yes then do we need to pull up MTP of each PMIC on board independently else address
conflict happens (default I2C address is fixed at 0Ah).
How to make sure voltage levels and sequencing before programming in MTP as we have limited chances to be correct. Do GUI provides any feature to do so..
Can we program in to working registers before programming in to MTP to check rail sequencing and voltage level and other parameters. If so how to do it.
Any document of such kind will be of great help.
Kindly address my queries asap.
Thanks in advance.
Thanks in advance.
Labels
Technical Center
