Apr 15, 2022
01:43 AM
Apr 15, 2022
01:43 AM
Hi there, is it possible to use INA3221 Current Sensor to measure only voltages at the three output channels without anything on the input bus? I am wondering if it is possible to use this module in a reverse direction, and have CH1, CH2 and CH3 voltage readings separately and maybe then allow CH1 to pass through the input bus using a switch transistor. Something like a voltage detect and then passthrough in the opposite direction from CH1 CH2 CH3 to input bus.
05:37 AM
Apr 16, 2022
05:37 AM
Hello @Bryant11
This forum can be used for Infineon products please contact to concern supplier
Guru
