Other Technologies General Forum Discussions
User16818
Hello,I am looking for a development guide on how to implement a simple circuit for programming the device in the final production board. This is necessary because we can not buy a pre-programmed version, less than 3000 units. In that case we must buy the non programmed version.
I found in the IRPS5401 programming guide chapter 2 a simple circuit but in combination with the application circuit its not easy to realise that additionaly.
My current circuit approch is an additional 6 pin connector an a 16 pin ( switch for normal and programming position (However, this is a very expensive solution, only the switch costs 12 Euro).
Is there a recommended solution for in-board programming? For good advice, I would be grateful.
Kind regards
Mike
