My name is Dan Radut and I started recently a project that is supposed to use a PSoC 4200L.
I have designed the schematic below that turns alternatively ON/OFF the output signal Gen_ON_OFFn
each time when pressing the Switch2.
Please could someone explain why the Build issues this error message when the output digital pin
Gen _ON_OFFn is attached to the TFF output:
mkdepend: error: cannot open ""
The command 'mkdepend' failed with exit code '1'.
This is the schematic:
The pin assignments are:
SW2 P0[7]
Gen_ON_OFFn P5[4]
UART:rx P4[0]
UART:tx P4[1]
Your comments and help will be highly appreciated,
Dan Radut
Hi Dan,
I am using the latest version of PSoC Creator i.e. PSoC Creator 4.3 at my side. I am not able to see any issue during build process. The build is successful with your schematic. Please check the attached project at your side too.
Ganesh
