Feb 26, 2021
11:46 PM
Feb 26, 2021
11:46 PM
Hi team,
am currently working on Dps310 pressure sensor,my query is on pressure readings,am unable to get stable pressure readings when am taking readings for 30-40min, while ploting it and checking,
1.My pressure configurations are as below
128mr/sec for pressure and oversampling is single(low precision mode)
128mr/sec for temperature and oversampling is 2 times configured
2.what could be the configuration will you prefer to get stable pressure readings
3.what could be the reason for pressure variation,is it necessary to maintain oversampling same for both pressure and temperature ,so that pressure doesn't varies
4.will temperature is effecting pressure readings,as am using one temperature variable in pressure calculation
5.what will be the co-relation between temperature and pressure,and how much will be the value of change in temperature will affect the pressure readings
thanks in advance
suraj.n
thanks in advance
suraj.n
Labels
Technical Center
