Feedback about AN1089: https://www.cypress.com/file/136121/download
In tables for CRC32 there are errors in columns R7-R22, R27.
There's an excel file in attach with correct table.
Green cells - must be added to columns; red cells in xN rows - xN must be deleted from columns.
Didn't find any mail contacts or form for documentation feedback, so just leave this here.
Community Information
Thank you very much for the feedback.
Appreciate if you can also elaborate a little on why.
I did a module with all bit as written in AN and it not works in simulator for bytes excepts MS.
Then i did 16 steps in excel and get different result. Then i just check this result for some inputs and compare output with online CRC32 generators. It works fine.
Sadly, i overwrite this file with file from topik's attach, but can make it again if needed.
