Hello Community,
I'm reading this document:
Microsoft Word - mcu-an-300213-e-v13-16fx_flash_security.doc (fujitsu.com)
In section 2.1 the document sais:
'[...] If the supplied Unlock Key is all 0, the Flash Security cannot be disabled at all.'
My question is: If I set the Unlock Key fully with zeros, then will I be able to perform a Chip Erase with the CYPRESS FLASH MCU Programmer after this full-zero setting is applied?
Thank in advance,
Gabor
Other Legacy MCU
Dear Gabor,
Sorry for the misunderstanding. The answer to your question is yes. If you set the Unlock Key fully with zeros, you will still be able to perform a Chip Erase with the CYPRESS FLASH MCU Programmer after this full-zero setting is applied.
Roy
