Hi, I'm new to this compiler but have some experience with gcc and arm compiler.
I want to make sure, 2 source files will end up producing the same object files.
So I was trying to compare the compiler output object files (somefile.o), generated from different projects.
I know that in order to do this I need to remove the added debug information from the object files.
In gcc we have the following command:
strip *.o
With arm compiler we can use:
arm-none-eabi-strip *.o
And with the fcc907s Cmpiler ???
I was also trying to use the -Xg flag, to not generate the debug information. this did not work for me (as can be seen in the image bellow).
Compare method: I generate an object file, cut and paste it somewhere else, regenerate it again and text compare it with the pasted file.
How can I compare 2 object files?
Is there's another way to make sure, 2 source files will end up producing the same object files?
Thanks in advance.
Other Legacy MCU
- softune c compiler
Dear author,
Checked SOFTUNE C Compiler Manual, and "-Xg" option exits.
However, it is to cancel "-g" and seems to be not remove debug information.
could you please check the "SOFTUNE C Compiler Manual?
And since the maintenance of "SOFTUNE" has been terminated, so if you need further support, please contact to CY/IFX sales representative.
SOFTUNE™ C Compiler Manual
