Hi,the following page https://github.com/Infineon/optiga-trust-m/wiki/Data-and-Key-Store-Overview says about data-retention-after-testing that "this time is the same as the device lifetime defined in the data sheet."
Where can i find this information? Can you give me more details?
If i write a data object like 0xF1D0 once after production, how long is this information retained?
Regards.
Hello @matteofumagalli
You can find the data sheet here.
Excerpt from the data sheet on lifetime:
Lifetime for Industrial Automation and Infrastructure is 20 years and 15 years for other Application Profiles.
Depending on where you deploy the OPTIGA™ Trust M device as per the above excerpt, the data is reliable for 15-20 years.
