SLM9670AQ20FW1311XTMA1
chaitu464
First reply posted 5 sign-ins First question asked
How to get Device ID of SLM9670AQ20FW1311XTMA1
Sharath_V
First comment on blog 250 sign-ins 100 replies posted
Hi @chaitu464 ,
As mentioned by @Sneha_P , the solution to your problem is available in a confidential databook. Could you please check internally within your company if you have access to myicp and the confidential documents (databook) of TPM design decisions? Please check if the databook has enough hints for you to provide the solution.
Please provide feedback on the same so we can support appropriately over private channels (but only as long as your company has signed NDA, which you need to check and let us know).
Sneha_P
50 likes received 250 replies posted 250 sign-ins
Hi @chaitu464,
Could you please specify what you mean by device ID and for what purpose you need the device ID of SLM9670.
Sneha
chaitu464
We are trying to read TPM_DID_VID_x, From TCG Administration doc we found out VID is x15D1 for Infineon. We are using SLM9670AQ20FW1311XTMA1  chip, as per datasheet, Device ID – vendor specific.
Sneha_P
Hi @chaitu464 ,
The databook contains the Device ID information you are looking for and it can be downloaded only from MyIcp.com.
Please login your account to download.
If you can't find the databook, please contact your distributor.
Sharath_V
Hi @chaitu464 ,
Sneha_P
Hi @chaitu464,
Please let us know if your query was resolved. We will lock the thread in 3 days. In case your problem is not resolved, please create a new thread and we will be happy to help.
