Hello, Infineon community,
I'm trying to find out more about SLB 9665TT2.0 SHA256 and Linux support, hope you can provide some clarity. According to the datasheet, this TPM chip supports 2.0 standards, but there is an issue when using it to create/store/seal FDE hashes. Detailed background info is logged here. TL;DR Linux kernel does not recognize SHA256 - although it's there and it thinks only SHA1 is available. The FW is 5.62, provided by Intel for the NUC5 platform.
- Does this chip SLB 9665TT2.0 provides SHA256[not a hardware limitation]?
- Which Linux kernel supports it?
- Is there a way to disable SHA1 in favour of SHA256 [ hardware or software ]?
- Does it need a newer FW 5.63? Where I can find it?
Any thoughts or experience with this will be much appreciated!
Kind regards,
Martin
Hi @mveplus ,
SLB 9665TT2.0 has 1 PCR bank supporting SHA1 or SHA256. You can execute a new "allocate" function (TPM2_PCR_Allocate) to change the PCR bank configurations. Please refer to section 22.5 for more details.
The change will be active after a system restart.
For FWs and the upgrade tool, please login to myICP (requires NDA).
Sneha
Good morning @snehapra,
Much appreciate your insights on this silicon's capabilities!
Is this something that can be done from the OS level or must be done in UEFI firmware?
Can a UEFI executable perform the (TPM2_PCR_Allocate) to change the PCR bank configurations before switching to Secure Boot [unsigned EFI binary ]?
N.B. Intel NUC support will not help with any UEFi firmware modifications as per their comment here.
Kind regards,
Martin
Hi @mveplus ,
You can bring up TPM driver under Linux environment and use tpm2_tools to allocate the PCR bank (application note).
Command reference: https://github.com/tpm2-software/tpm2-tools/blob/master/man/tpm2_pcrallocate.1.md
Note: This command requires platform authorization
We also have an Infineon tool with UEFI support to perform the PCR allocation, but this tool access is provided only to users with an NDA.
Hope this helps!
Sneha
