Nor Flash Forum Discussions
simchap
First question asked Welcome!
I need Verilog model for flash:
S28HS02GTFPBHM05
Simcha
AS_36
Hi Simcha,
The verilog model for S28HS02GT device is available here - https://community.infineon.com/t5/Semper-Flash-Access-Program/S28HS02GT-Octal-Verilog-Model/ta-p/323...
You will be able to access the above link only if you are a part of the SEMPER Early Access Program. If you have not yet registered for the SEMPER EAP, you can do so by filling the form on this link - https://infineoncommunity.com/semper-eap. Once your request is approved internally, you will be able to access the model.
Regards.
AS_36
Hi Simcha,
Regards.
