Nor Flash Forum Discussions
Shraddha
First solution authored 50 sign-ins 10 questions asked
hello ,
 I had implemented the QSPI, the problem which I'm facing is that
1)  to read the device id , configuration register 1 and 2 both through spi , first I tried to read the configuration register 2 i.e.  in 1s-1s-1s and then it was showing 08 by default value , that was working well
2) after that i tried to write on the memory 0x00800003 then after that it got converted to  (4s-4s-4s) format
3)when I'm trying to read the cfgr 2 in  4s-4s-4s  it not accepting the command which i had used
Read Mode:- CS(high)--->CS(low)--->cmd(65)--->address(0x00800003)---->read cycles
Write Mode:- CS(High)--->CS(low)---->cmd(06)--->cmd(71)--->cmd(0x00800003)--->cmd(68)
Read Mode:- CS(High)---->CS(low)----> cmd(65)--->cmd(0x00800003)--->read cycles
its not working let me know where I'am going wrong output wave form i have attached
AlbertB_56
500 replies posted 50 likes received 250 replies posted
Hello Shraddha,
In 4S-4S-4S Quad mode, please verify and confirm that Config. Register-1 (CFR1N[1] = 02h, which sets Quad SPI Interface I/O width to 4 bits.  The contents of Config. Register-2 (CFR2N[7:0]) = 68h.   In the waveforms attached, I do not see the register settings for Config. Register-1.
Albert
Cypress Semiconductor Corp.
An Infineon Technologies Company
AlbertB_56
Hello Shraddha,
Albert
Shraddha
First of all these all configuration i did only for configuration register 2 ,
1. i want to write first in Configuration register 2  so therefore iam writing 68 to enable quad mode (4s-4s-4s) that it self its not writing, when iam trying to read MISO line is not triggering only
basically my plan was to enable first configuration register 2(4s-4s-4s) then configuration register 1(1s-4s-4s)
configuration register 2 itself is not happening
can you please tell me the whole format ,its urgent
AlbertB_56
Hello Shraddha,
Using the address of 0x00800003, you are attempting to read from, and write to, volatile Config Register-2 (CFR2V). Therefore, to write 68h to CFR2V, use the WRENV_0_0 (command 50h), instead of WRENB_0_0 (command 06h), as the volatile Status and Configuration registers, can be written by sending the WRENV_0_0 transaction, followed
by any write register transactions (WRAR : command 71h).
Before the Write Registers transaction can be accepted by the device, a Write Enable (WREN_0_0), or Write
Enable for Volatile Registers (WRENV_0_0) transaction must be received. After the Write Enable command has been decoded successfully, the device will set the WRPGEN in the Status Register to enable any write operations.
Please let me know of your findings.
Albert
Shraddha
command to write in configuration register 2
cs(high)--->cs(low)--->cmd (50)write enable volatile--->cs (high)--->cs (low)--->cmd (65)read status register 1--->address (0x00800000)--------->read cycles( 8 bit)--->cs (high)--->cs (low) ----> cmd (71)write--->(address cfgr 2)0x00800003------>data(68)--->cs (high)--->cs (low)--------->cmd (65)read cfgr register 2--->address (0x00800003)---->read cycles( 8 bit)--->cs (high)
data i can see is 11 its some junk data what is the issue
