Nor Flash
AVHo_4385401
New Contributor
Maybe someone will be useful.
ST chips have qspi support in extended memory mode. Reading is fully automatic, but for recording you have to switch to manual mode.
To speed up the algorithm - the driver does not have extended support for all existing memory chips. Because in such devices the memory is installed on the PC, it is one and should not change.
For use with another memory - you need to fix several lines.
Bitbucket
