Nor Flash
MAO
First like received 10 replies posted 25 sign-ins
DDR Quad Read 66MHz and SDR Quad Read 133MHz in the data sheet
There was, but please tell me the difference.
NoAr_1540581
Level 5
100 replies posted 100 sign-ins 50 replies posted
Level 5
Hello
The main difference is SDR and DDR. SDR reads the data at the rising edge of the external clock signal.
On the other hand, DDR reads data at the rising and falling edges of the external clock signal at each timing, so data can be simply transferred at twice the speed. However, when considering the actual transfer rate, it is necessary to consider the difference in Clock Rate (MHz) (example: Quad Read 66MHz / 133MHz).
Best Regards
Arai
NoAr_1540581
Level 5
Level 5
Hello
Best Regards
Arai
