Nor Flash Forum Discussions
jusac_3935691
First reply posted First question asked
hi.
I found information about NOR Flash in the following document.
http://www.cypress.com/file/275051/download
P. 23  3.3.5 NOR Flash
And I want to use this, but I can't find any sample programs of S25FL132K.
I found sample programs of S25l164K(FM_PDL_2.0.1/example/hsspi/hsspi_access_s25l164k),
but it doesn't work on FM0+.
Where is the document which shows me how to use S25FL132K ?
thanks.
You can use source code available at following folder to use our flash device, FM_PDL_2.0.1\utility\qspi_flash. It can be used to access S25FL132K device. Please let us know if you face any errors.
Thanks and Regards,
Sudheesh
SudheeshK
250 sign-ins First question asked 750 replies posted
Sorry for the delay in our response.
The project that you mentioned "FM_PDL_2.0.1/example/hsspi/hsspi_access_s25l164k" will work for FM0+ device.
Could you please let us know the details of error that you observe with this project?
Thanks and Regards,
Sudheesh
hi.
Thank you for your response.
Sorry my incorrect expression. I tried to build the sample to use on FM0-64L-S6E1C3 Complete Starter Kit.
Then the following error macro activated.
FM_PDL_2.0.1/example/hsspi/hsspi_access_s25l164k/main.c
54 #if (PDL_MCU_SERIES != PDL_DEVICE_SERIES_S6E2CCX)
55 #error This example is developed on SK-FM4-178L-S6E2CC board!
56 #endif
Can I use on S6E1C?
What really want to do is using S25l132k via SPI, and I noticed CSIO can use as SPI.
And I also noticed NOR Flash Test is already run. (I forgot...)
P. 17
Can I get source cord of this test (or near one) ?
thanks.
Thanks and Regards,
Sudheesh
