Hi @Tomer
The mentioned part numbers are for SEMPER NOR flash. I would like to request you to kindly register for the SEMPER Early Access Program to get access to all SEMPER related documentation. You can register yourself here - https://infineoncommunity.com/semper-eap. Once you fill the form on the provided link, you will receive an email asking for some more information. Please kindly respond. Once you have responded and your request is internally approved, you will receive the invite to join the SEMPER community in your community inbox.
After all the above process is complete, you will be able to access the datasheet for S28HS02GT device here - https://community.infineon.com/t5/Semper-Flash-Access-Program/Datasheet-2Gb-MCP-Semper-Flash-with-Oc...
Hope this answers your query. Do let me know if you have more questions.
Regards.
Hi @Tomer
Regards.
