confirm device ID for S29GL01GT12DHVV10
damc_2280741
Using device S29GL01GT12DHVV10.  Trying to use the device ID and noticed the data sheets for S29GL01GT and S29GL01GS appear to have the same device IDs, even though they are built on different process nodes.  Is it correct that they have the same device IDs?  Please confirm the correct device ID for S29GL01GT12.
Yes they have the same Device ID.
Thank you
Bushra
BushraH_91
750 replies posted 50 likes received 250 solutions authored
Thank you for contacting Cypress Technical Support, an Infineon Technology Company. Yes it is correct, S29GL01GT and S29GL01GS have the same Device IDs.
Bushra
damc_2280741
Bushra,
Thanks for the feedback.  Do they have the same device ID then because the programming models, erase processes, memory map are the same?  Thx,
Dan
Thank you
Bushra
