Dear supporter
Infineon TC3 family has Queued SPI function which can achieve serial interface.
Please let me know if Cypress Quad SPI NOR Flash memory would be suitable on communication with this function in the follwing clock rate.
Please refer to the following spec Page-2.
https://www.cypress.com/file/209446/download
And regarding this definition, "MBps" means mega Bit per sec ? Or mega Byte per sec ?
The following definition shows current consumption with several reading speeds in spec Page-2.
Is the high speed reading value in the following table depend on MCU baud rate setting ?
Nino
Serial NOR
The SPI clock frequency depends on the MCU and should not exceed the maximum frequency specified in the datasheet.
