Will the S70FS01GS device work with Zynq UltraScale for booting?
AN98507 mentions S70FL01GS, but will S70FS01GS work too?
Thank you.
Memory Nor Flash
- S70FL01GS Flash is supported with Vivado tool suite on Zynq UltraScale
- S70FS01GS Flash is
- Not supported on Vivado tool suite on Zynq UltraScale
- Can be used under U-Boot scheme with Zynq UltraScale
Please refer to url and attached document for more detail information: https://www.xilinx.com/content/dam/xilinx/support/documentation/sw_manuals/xilinx2021_1/ug908-vivado...
Thank you
Bushra
Thank you for contacting Cypress Community Forum, an Infineon Technologies. Currently we are reviewing your issues and will get back to you as soon as we find the resolution.
Bushra
Thank you
Bushra
Yes it should work and boot in Single I/O.
However, we have not tested in on a Xilinx platform, so I would advise you to get couple of samples and verify that it works correctly.
Thank you
Bushra
