I need a guru to help me here. We bought a bunch of Cypress flash memories S34ML04G204BHI01 and we also have some Cypress S34ML04G204BHI003 from the past. I couldn't find the S34ML04G204BHI003 online anymore, I am assuming it's end of life. My question is what the difference is between S34ML04G204BHI01 and S34ML04G204BHI003? Is there any firmware change required from S34ML04G204BHI003 to S34ML04G204BHI01 at all?
Infineon currently do not have NAND memory business. We request you to contact SkyHigh memory for all your queries related to NAND flash devices.
Infineon Press Release: Cypress Announces Closing of Joint Venture Transaction with SK hynix system ic
Thank you
Bushra
It's S34ML04G204BHI010.
Thank you
Bushra
