Nor Flash Forum Discussions
GrCa_1363456
First comment on KBA First comment on blog 250 sign-ins
What is process to program S25FL256L QSPI flash for Intel Altera Cyclone V E FPGA?
We are NOT able to program S25FL256L using Intel’s Quartus Programmer.
The error is Silicon ID not detected for device 1.
This may be similar to a post that has NOT been resolved
There are two similar posts that have been solved, which aren’t the exact issue:
Greg
Yuvraj
250 sign-ins 50 solutions authored 100 replies posted
With the Intel Cyclone V, you are booting from Hard Processor System (HPS), then our S25FL256L Flash is not supported by Intel.
The alternative Infineon 256Mb QSPI Flash to be used is our S25FL256SAGMFI00 which is supported by Intel on the HPS of Cyclone V: https://www.intel.com/content/www/us/en/support/programmable/support-resources/devices/supported-fla...
In the thread which you are mentioning uses the Flash in Active Serial (AS) SPI configuration mode, our S25FL256L has the right features and architecture to be used on Cyclone V.
Our S25FL256L Flash is not directly supported.
Hope it clarifies your query.
Yuvraj
Yuvraj
Yuvraj
