- Email to a Friend
To what extent is S25FL256L Flash memory Opcode compatibile with EPCQ standard & Intel ASMI parallel intel IP?
In the S25FL256L datasheet, some opcode are not compatible/ missing.
Greg
Memory Nor Flash
- Email to a Friend
Thank you for contacting Infineon Technologies.
Could you please let us know which FPGA board you are using.
If you are using Altera® FPGA Board you can use following application note: https://www.infineon.com/dgdl/Infineon-AN98558_In-System_Programming_for_Infineon_SPI_Flash_on_Alter...
Thanks and regards,
Yuvraj
- Email to a Friend
Thanks and regards,
Yuvraj
