Nor Flash Forum Discussions
huqic_3861581
Hi
   We currently use the chip of S29GL128P10TF101. Has it stopped production? Can alternative models be provided? Thank you
Roy_Liu
1000 replies posted 500 solutions authored 5 questions asked
Roy_Liu
S29GL128P10TF101 is 90-nm technology part, it is  not stopped production. But new design, the recommendation is to use 65-nm part S29GL128S10TFI01 part:
Datasheet: http://www.cypress.com/documentation/datasheets/s29gl01gs-s29gl512s-s29gl256s-s29gl128s-1-gbit-128-m...
Migration guide: http://www.cypress.com/documentation/application-notes/an98586-migration-gl-n-and-gl-p-gl-s-flash
Or if you want higher desity, you can consider 40-nm part:
Datasheet - http://www.cypress.com/documentation/datasheets/s29gl01gts29gl512t-1-gb-128-mb-512-mb-64-mb-gl-t-mir...
Migration guide - http://www.cypress.com/documentation/application-notes/an202453-migration-gl-p-and-gl-s-gl-t-flash
Roy Liu
