Nor Flash Forum Discussions
yushc_1313201
Hello ,
The S70GL02GS has two sector protection models.
Highest address protection model ,lowest address protection model
Could you please tell us each application .
Yutaka Shimoeda
Hello Shimoeda San,
If the customer wants to protect some of the sectors from program or erase operations where once the data is programmed it does not require to be updated/modified  then we provide the option through Highest sector protection or Lowest address sector protection.
For ex : Important programs like boot codes will not change through out the life time of application. IN this case customer can choose to program the code in to either highest or lowest and can get it protected. Please note that once it is locked it can not be changed.
User can choose which sector to be protected Highest or lowest depending on their choice and order part umber accordingly.
Hope it clarifies your query.
Krishna.
Hello Shimoeda San,
Krishna.
Hello Krishna.-san,
Thank you for your support .
Yutaka Shimoeda
S70GL02GS as either highest or lowest address sector protected part. I am using V2 - Corresponds to Lowest address sector protected. What will the memory size does it protect? Please confirm
