toyac_1469256
Level 4
Level 4
Q1: WP # terminal
If Quad command or Write protection is not used in the host system, the WP# pin can be left open, but is there a problem with using the WP# pin fixed at VDD (3.3 V)?
Q2: RESET # terminal
If Quad command or Reset is not used in the host system, the RESET# pin can be left open, but is there a problem with using the RESET# pin fixed at VDD (3.3 V)?
Hello Yamakoshi San,
You can connect  WP# and RESET# pin to VDD (3.3V) . There will not be any problem as long as you are not going to use those pins.
Krishna.
Krishna.
toyac_1469256
Level 4
Level 4
Hello Krishna San,
Thanks for your reply.
