Nor Flash Forum Discussions
ViC_3886151
Hello everyone.
I'm using PSoC 5LP in my project. Can someone please guide me regarding how to use Spansion SLLD v13.2.1 with S25FL127S serial NOR flash?
The flash is used to create a file and log some data.
Thanks in advance.
Vinay
Hi Vinay,
I will clarify my previous response. If you already have source code for a file system then you can use our sLLD along with it and create files on our flash device. You won't be able to create files on our device if you are using only our sLLD.
I think you already have a file system source code with you. Please correct me if I am wrong.
Thanks and Regards,
Sudheesh
SudheeshK
250 sign-ins First question asked 750 replies posted
Hi Vinay,
You can use the user guide available with our SLLD v13.2.1 to use it in your application, http://www.cypress.com/documentation/software-and-drivers/low-level-driver-spi-flash?source=search&c... . But, you won't be able to create a file in our flash device using sLLD, are you using any file system in your application?
Thanks and Regards,Sudheesh
Hi Sudheesh,
Thanks for the reply. I am using FAT16/32 file system in which I have to create a file to store the data. If SLLD cannot be used to create a file, then what is the alternative?
Thanks and Regards,
Vinay
Hi Vinay,
Thanks and Regards,
Sudheesh
AlbertB_56
500 replies posted 50 likes received 250 replies posted
Hello Vinay,
As Sudheesh had already mentioned.  Cypress had already sent you the Cypress FLASH File System (FFS) package
on Thursday (29NOV2018) at 8:55a, Pacific Standard Time (PST).  The Case number is #470977.  Please thoroughly
check your e-mail in-box, clutter in-box, and/or junk in-box.
All three segments of the Cypress FLASH File System had already been sent to you...Case#470977.
Albert
Cypress Semiconductor
Hello Albert,
Thanks for the sharing the Cypress FFS. I'll go through it and get to you if required.
Vinay
