Nor Flash Forum Discussions
MoSa_4200611
First like given
It is mentioned in the specification that "The LSb of the address always be zero in any Octal DDR transactions with the address input."
1) Does this apply to any read or write transaction?
2) How can this work for WRARG (Write Any Register) where such commands are meant to access one register location (one byte) only. It is clearly mentioned in the specification that : "The Write Any Register (WRARG_C_1 / WRARG_4_1) transaction provides a way to write any device register, nonvolatile or volatile.
The transaction includes the address of the register to be written, followed by one byte of data to write in the addressed register (see
Section 6. Transaction Table)."
Then, how can odd addressed registers be written? For instance, CR2 (at address 0x00800003)
Thank you for your patience...
The statement, "The LSb of the address always be zero in any Octal DDR transactions with the address input"  does not apply to any
READ or WRITE transactions, nor does this statement apply to the Write Any Register (WRARG) command.
For register write, provide the same register address as mentioned in the datasheet, as it it not needed to put A0=0 for register access
This comment is also true for memory array read/write operations.
Hope this helps...
Albert
Cypress Semiconductor Corp.
An Infineon Technologies Company
AlbertB_56
500 replies posted 50 likes received 250 replies posted
Thank you for contacting Cypress Semiconductor
We are currently reviewing your query and we will respond
back to you as soon as new information becomes available.
Albert
Hope this helps...
Albert
