Sector Erase Suspend time specification (min and max) for S29GL032N NOR Flash
Anilsp31
25 sign-ins 5 replies posted 10 questions asked
We are planning to use Erase Suspend and Resume operations for S29GL032N NOR Flash in our product.
We want to know how much time Erase Suspend command execution will take (min and max values).
This time is not given in the datasheet.
Anil Patil
BushraH_91
750 replies posted 50 likes received 250 solutions authored
Thank you for contacting Infineon Technology. How long  you are initiating the Erase suspend command?
As long as sufficient power is applied to the flash, you can initiate the Erase suspend/resume command, as many times as you want. The erase suspend command is end user defined.
Thank you
Bushra
BushraH_91
Thank you
Bushra
