Iam giving the configuration correct as you mentioned
read command for status registers 65h
write into volatile register cmd 50 after that 71h address data type
for reading device id AF mode
you can refer the memory window
Hello Shraddha,
< 2nd Notice >
Thank you for contacting Infineon Technologies.
Configuration Register-1, bit-1 (CFR1N[1]) and Configuration Register-2, bit-6 (CFR2N[6]) must both be set to configure the S25HL512T into the QUAD mode, hence:
CFR1N[1] = QUADIT = Quad SPI Interface Selection - I/O width set to 4 bits
Selection Options (either '1' or '0'):
0 = Data Width set to 1 or 2 bits wide (1x - Single, 2x - Dual)
1 = Data Width set to 4 wide (4x - Quad)
CFR2N[6] = QPI-IT = QPI Interface & Protocol Selection - I/O width set to 4 bits (4-4-4)
0 = Data Width set to 1 or 2 bits wide (1x - Single, 2x - Dual) - Legacy Protocol
1 = Data Width set to 4 wide (4x - Quad) - QPI Protocol
With regards to the Quad Transaction names for 1S-4S-4S or 4S-4S-4S, use transaction name " RDQID_0_0 ".
What are the current register settings for CFR1 and CFR2?
Albert
Cypress Semiconductor Corp.
Infineon Technologies Company.
Hello Shraddha,
Albert
Hello Shraddha,
< 2nd Notice >
Albert
hey albert ,
its working fine thanks for you updates
