Nor Flash Forum Discussions
Shraddha
First solution authored 50 sign-ins 10 questions asked
For Writing into the multiple memory locations in an loop
iam giving commands
write enable 50---> write command 01 in which i'am writing into STR 1 ,cfgr1,2,3,4---->in for  loop{ write memory (02) followed by starting address and data }
Is this sequence correct?  i'am able to write only at one memory location after that if is not accepting when iam trying to read i got to Know it is not programmed , only starting memory location is programmed.
what is the issue ? despite of giving enough latencies after each write still its not taking
Yuvraj
250 sign-ins 50 solutions authored 100 replies posted
Hi Shraddha,
For S25HL512T does not support write command 01.
Please refer the Write any register transaction of page 56/141 of the data sheet.
Please register SEMPER Secure Solution program by following link: https://www.infineon.com/cms/en/product/promopages/semper-solutions-hub/
Where you will get SDK (Semper Development Kit).
Can you please share your program code and logic analysis traces of the operation you are performing.
Yuvraj
Yuvraj
Hi Shraddha,
Thank you for contacting Infineon Technologies.
Can you please provide the waveform of the operation?
Yuvraj
Shraddha
hey i'am sharing the snap of memory window in which you ca see i'am able to write only in 1 memory location data a5 rest  two of them are not even programmed why is so ?
Yuvraj
Hi Shraddha,
Yuvraj
