Nor Flash Forum Discussions
amku_4419401
First question asked Welcome!
Short one..
To read device id and manufacturer id from dual die S70GL02GT device, what would be the command sequence ?
We are using device in x16 mode.
a) Is it this ..
< 2 Byte writes at addresses.>
*(u16 *) 555 = 0xaaaa // unlock 1
*(u16 *) 2AA = 0x5555 // unlock 2
*(u16 *) 555 = 0x9090 // Command.
Read flash device at base address for first die
and set A26 high for second die and repeat a) ?
BushraH_91
250 solutions authored First comment on blog 500 replies posted
Second die is same as first die. The device ID for first die is the same as second die. Therefore A26 does not have any relevance reading Device ID. Refer to S70GL02GT datasheet Distinctive Characteristics and go bullet # 2.
Device Id in x16 mode is (ID-CFI):
Cycle 1 = 227Eh
Cycle 2 = 2248h
Cycle 3 = 2201h
URL for datasheet: https://www.cypress.com/file/310666/download
Thank you
Bushra
BushraH_91
Thank you for contacting Cypress Technical Support, an Infineon Technologies Company. Currently we are reviewing your issue and will get back to you as soon as we find the resolution.
Bushra
BushraH_91
Cycle 1 = 227Eh
Cycle 2 = 2248h
Cycle 3 = 2201h
Thank you
Bushra
